JD 1020 question
Tufunuf
02-26-2004 08:33:40
This is going to be hard for me to explain. But, here goes.
A fella has a John Deer 1020 gas that the hydraulic lift is not raising or lowering. But, someone had him hook up a hydraulic hose from a connection on the underside of the tractor, below the running board on the right side to another connection port on the exact opposite side of the tractor (same location under the running board, but on the oppsite side of the tractor) and...guess what? The hydraulic lift works as long as the hose is connected!
Can someone tell me what is happening here, and what is wrong with the lift in the first place?
Thanks,
Tuf
david val
02-26-2004 12:19:09
 Re: JD 1020 question in reply to Tufunuf, 02-26-2004 08:33:40
doesn't make sense, if it doesn't raise how can you tell it doesn't lower? raising requires pressure, lowering is by wheight. if you supply direct pressure it can 'solve' the raising problem but not the lowering problem.
what comes into mind is a connection from the pressure T under the right footstep to the piston pressure connection on the left side of the rockshaft. the lift will 'limp' but probably work somehow with oil heating and other problems.
lift problems in 1020 are quite simple to diagnose and repair.
david
Tufunuf
02-26-2004 13:18:46
 Re: Re: JD 1020 question in reply to david val, 02-26-2004 12:19:09
I stand corrected. It will raise but not lower. You said 1020 lift problems were easily diagnosed. How so?
Tuf
david val
02-27-2004 08:07:24
 Re: Re: Re: JD 1020 question in reply to Tufunuf, 02-26-2004 13:18:46
for whoever knows the system, diagnosis and repair are pretty simple. in order to diagnose, you need of course, to know exactly what the problem is and when and how it started. you also need to know how the rest of the high pressure hydraulics is functioning.
there are two common reasons for arms raising but not lowering: 1- the rate of drop valve under the seat is fully closed. 2- the load control cam is broken or not seating properly on it's roller.
david
