1010 SPECIAL HYDRAULIC OIL
Scotty
06-24-2005 07:38:17
I HAVE A 1963 1010 SPECIAL AND WOULD LIKE TO KNOW WHAT TYPE OF OIL DO I USE FOR THE HYDRAULICS AND CAN I USE A REGULAR GEAR OIL FOR THE FINAL DRIVES AND TRANS. ? THANKS FOR YOUR TIME AND HELP. SCOTT
Mike M
06-24-2005 10:42:28
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Scotty, 06-24-2005 07:38:17
Scott; That JD 303 oil was replaced by Hy-Gard reg vis. not the low vis.
James2
06-24-2005 13:23:02
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Mike M, 06-24-2005 10:42:28
That may well be true for JD303, but I looked in the John Deere Reference guide and it says:"Low-Viscosity Hy-Gard oil... for all combines, lawn and grounds care equipment... and other machines requiring hydraulic or hydrostatic oil". I have a JD 730, 430 and 830 and use low viscosity Hy-Gard in all, and also use it in several newer tractors.
Mike M
06-24-2005 19:17:33
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to James2, 06-24-2005 13:23:02
Combines and lawn and garden eq. are using the low vis in the hydro units as it is thinner.I'm sure that the old 1010 is half worn out and thicker oil will help it out I would stick with yhe reg. hy-gard as this was the direct replacement for 303 oil called for in the 1010 and others.
James2
06-25-2005 09:53:04
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Mike M, 06-24-2005 19:17:33
Mike:
No doubt that is pretty good advice you are giving. However, if one has a lot of tractors it's a little more complicated. Most "plain" hydraulic oil is 10W. Standard Hy-Gard must be 5w30 or 10W30, it's heavier than Agco's 821 which I know is 5W20. For my purpose, I want to stick as close to "plain" hyudraulic oil as possible without using it. I don't think the newer tractor's hydraulic system would like the heavier oil. I was just looking at the situation with "blinders on"; ie, considering only my circumstances.
James2
06-24-2005 10:21:55
I use low viscosity Hy-gard as a general replacement for hydraulic oil. I do this because some tractors have a combined hyd/trans reservior and others separate them, therefore when used on the same remote cylinders you can get "plain" hyd oil in the trans of the combined system tractor. I don't want "plain" hyd oil in a transmission therefore use Hy-gard in a tractor having the separate hydraulic reservior to avoid this concern. I use low viscosity because it has a viscosity more closely matched to hydraulic oil than standard Hy-gard. Synthetic Hy-gard would be ideal, but expensive. I know you could change cylinders, but some implements have special cylinders and buying double cylinders is not going to happen. As was indicated earlier just use standard 80W90, or 90w, or better yet 75W90 gear oil in the finals and transmission.
Henry J
06-24-2005 09:38:12
Scotty
You know about opinions right?
If it were mine I would feel comfortable seeing what JD recommended in the operators manual. That would at least present a reference point to start from.
Anyway, that would be my approach.
Sorry, I don't have on as new as yours so I can't give you the JD opinion.
Scotty
06-24-2005 10:18:17
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Henry J, 06-24-2005 09:38:12
THANKS, THE JD MANUAL SAID TO USE TYPE 303 SPEICAL PURPOSE OIL AND I DON'T REALLY KNOW WHAT THAT IS. I DIDN'T KNOW IF I COULD USE SOMETHING ELSE OR IF THERE IS A REPLACEMENT OIL FOR THE 303 SPEICAL PURPOSE OIL. THANKS ....SCOTT
Henry J
06-24-2005 14:17:28
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Scotty , 06-24-2005 10:18:17
Scott
Congratulations, there are a lot of folks out there flying by the seat of their pants. You were way ahead of me, I just did not have a clue.
buickanddeere
06-24-2005 08:05:08
GL-4 marine or GL-1 for trans and finals. Hyguard or approxed equal suitable for wet clutches.
Scotty
06-24-2005 10:25:58
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to buickanddeere, 06-24-2005 08:05:08
THANKS, IS THIS THE SAME OIL THAT GOES IN THE LOWER UNIT OR TILT AND TRIM ON A OUTBOARD MOTOR ? THANKS....SCOTTY
buickanddeere
06-24-2005 11:14:07
 Re: 1010 SPECIAL HYDRAULIC OIL in reply to Scotty , 06-24-2005 10:25:58
Yes the GL-4 Marine, not the GL-4. The GL-4 series are a higher pressure oil than GL-1. And the marine GL-4 does not attack copper based components. Is your 1010 a pre 31,000, 31,001 to 42,000, 42,001 to 52,??? something or above? The hydraulics went to a high pressure system at 42,001.
