CARB ADJUSTMENT ON JD 317 KOHLER
LYNDON SAMUEL
06-24-2005 07:28:01
MY 317 WILL NOT IDLE---SURGES AT LOW SPEED---HOW DO YOU ADJUST THE CARB
THANKS
buickanddeere
06-24-2005 11:17:13
 Re: CARB ADJUSTMENT ON JD 317 KOHLER in reply to LYNDON SAMUEL, 06-24-2005 07:28:01
Is the idle jet plugged? Rev the engine just enough to smooth out. Turn the main jet in so the only fuel the engine gets is from the idle circuit. She will quit in a hurry if the only flow of fuel was through the main jet.
Bob
06-24-2005 08:00:52
A worn throttle shaft ot loose linkage joints will make them surge, as well as a lean mixture. There are two brass mixture screws on the carburetor... screw sticking straight up is the main (load) mixture, and the screw sticking out at an angle is the idle mixture. Try opening the idle screw (CCW) 1/2 turn and see if that helps, and fine-tune from there.
