720 gas rebore kit.
Bill Tremel
06-24-2005 07:18:35
I have a 720 gas RC that we use daily on our farm. The engine is wore out and it is going to need rebored, sleved and new pistons/rings. I can find a rebuild kit for diesel's, but no one has them for the 720 gas.
I don't want to put in oversize pistons. I would like to bring the tractor back to the original bore.
Any thoughts?
PS (I'm looking for a good 3020D WF to use on the farm as well. I live near Pittsburgh, PA.)
Carl NY
06-24-2005 12:34:37
 Re: 720 gas rebore kit. in reply to Bill Tremel, 06-24-2005 07:18:35
Bill, I would suggest boring the block & installing oversized pistons & rings. I just finished a 620 which I had bored .125 thousands over. There is a good supply of pistons & rings available from std. to .125 over. It is well worth the time & expense.
Bill Tremel
06-25-2005 05:46:32
 Re: 720 gas rebore kit. in reply to Carl NY, 06-24-2005 12:34:37
Thanks for all the great comments. I think that boring out the block will be the way to go. I had put alot of new and rebuilt parts into this tractor over the past 7 years. We already rebuilt the carb (with new bushings, etc), rebuilt head, new intake and exhaust manifold, new main seals, new tires, etc. The only thing left is the block/pistons and I also have a sticking power steering issue.
With that all said, I think we'll rebore the tractor, paint it and retire her as soon as I find a replacement. The pore girl has done her time.
Thanks again for all the help.
--Bill
buickanddeere
06-24-2005 08:19:52
I'm not real certain what you mean, but the factory two cylinder blocks did not use dry or wet sleeves. The bores will be egg shaped by now and may or may not cleanup with 45 over unless the machinist gets her perfectly centred. Sleeving the engine back to stock bore with new rings on the old pistons is looking for trouble. The ring lands will be worn out and the piston pins worn. It will be cheaper to purchase new pistons rather than re-machining ring grooves and finding over size piston pins. Then you are still left with piston skirt wear. May as well install high alt pistons when in there. She shouldn't knock if set up correctly. The cam and followers may even look ok to the eye but they will be licked and require Roberts Carb to resurface all. Pull every part of that air intake system apart and remove the mud & grease that is almost certainly blocking it.New bushings on the carb throttle and choke shafts or it will never run 100%. There is a bushing in the distributor that will be worn too. New valve guides and machining for hardened seat inserts is mandatory. New valves maybe required as the stems do wear undersize.
Earl-IL
06-24-2005 08:04:09
815-778-1900 I think he has what you need. Good USA made pistons. Earl
Mike M
06-24-2005 07:40:32
Why would you not want to rebore to the next oversize ????? Are you standard now ?? JD offered .045 oversized they may still sell them,most of the gas engines sub over to the high altitude pistons.
