148 loader hydraulics
Nylon
06-23-2005 23:23:10
I forgot to mention that when I try to apply down pressure to the 148 loader hooked up to rear remotes, the loader automatically begins to raise. It almost seems like an auto function for fast loading. I often use mine for dirt work and need some down pressure. Is this a setting of some sort or a system leak/ failure? The bucket seems to hold its down pressure no problem. Also I noticed someone post info about a flow restrictor. I like a fast loader but also need it to be controlable.
JDJim
06-24-2005 05:38:56
 Re: 148 loader hydraulics in reply to Nylon, 06-23-2005 23:23:10
I have one as well with joystick control. Get a power block that bolts on behind the remote body from JD, hooks up direct and frees up your remotes. JD joystick is nice but expensive. If you use it regularly I feel its worth it. Good luck.
