John Deere 4020 148 loader
Nylon
06-23-2005 22:10:14
I just bought a 4020 w 148 loader. The tractor is very nice. The loader is thrashed. All the joints are sloppy and loose. Are there bushings that go into the pivot pin points to make those pins nice and tight? This includes the hydro cylinder points and bucket pins.
I would also like to run the loader with a joystick and take it off the rear dual hydraulics. Anyone made this conversion and have any tips/ suggestions?
Mike M
06-24-2005 05:49:50
 Re: John Deere 4020 148 loader in reply to Nylon, 06-23-2005 22:10:14
I think some of the ends have bushings,but if you have slop in the pins at the frames you have to cut off the old and weld on new bushings.
I have ours running off a seperate valve. I picked up a valve from a JD industrial loader.They are allready closed center,have load check valves and a regenerative circuit for the dump function. I bought a special tee fitting and hooked it in the line that feeds the rockshaft near the brake pedals. I return my oil back in the suction side of the charge pump (I think)I just kinda copied the 500 industrial loader set up my valve came from.It was just basically a 3020 power shift.Most people get a ported filter cover for the return oil.
Nylon
06-24-2005 11:40:33
 Re: John Deere 4020 148 loader in reply to Mike M, 06-24-2005 05:49:50
Thank you Mike. That is a good idea. I don't necessarily need a joy stick. Just valves that I can mount at arm rest length relative to the seat.
The regeneration function on the bucket, explain what that does. Is that what I have going on in my loader arms and possibly someone reversed the lines? Instead of getting down pressure...I get some down pressure, then the loader begins to lift slowly on its own till I move the valve again. If I were to swap lines to the valves the bucket would dump and if I just held it down till it started to return and let go the bucket would return?
You can call me a jocky. I spent alot of time on a grade b dairy where we had an M (loader tractor...narrow), a 9n and a 4020 with no loader. They retired 20 years ago. I bought a 4020 from relatives who were retiring now and have some work on the loader to do. I will use tractor for haying some and dirt work and woods work.
Mike M
06-24-2005 19:29:22
 Re: John Deere 4020 148 loader in reply to Nylon, 06-24-2005 11:40:33
I'm not sure what is going on with yours hard to visualise ? It may be a high pressure leak in your valves. You are using your remotes aren't you ? These I think have some adjustments on them. That regenerative feature I think is for when you are dumping a full bucket,the extra weight will make it dump fast so this forces oil out of your cyls. fast letting air get in the other side. This feature I think routes the oil from one side of the dump cyls. to the other so they stay full of oil so they return back up normal instead of jerky trying to get the air out.
