Brian: Well, with the ignition switch in the "On" position, the power is still flowing to the breaker points, and if they are open, then it is trying to flow within the small wires of the ignition coil. That's where the power drain is, and its pretty normal for a load like that to drain a good battery down overnight. If you have lots of good cranking with your starter, you could run a wire from the starter switch to power the coil during cranking (it might already have one, but I'm not sure), then install a low pressure oil pressure switch in line with the oil pressure gauge. That way, when you step on the starter, the current will flow, and the moment the engine develops sufficient oil pressure, the switch will close and it will run on it's own. If you turn have your throttle set so that you can pull it back so far as to kill the engine that way, the oil pressure will fall, the switch will open and the power will cease to flow. Now the danger in this method is that if a child or an unsuspecting adult steps on the starter, the engine could start, so I recommend that you maintain the ignition switch and try to remember it. You could also install an oil pressure switch that would fire a small light and/or a buzzer which would remind you that you need to turn off the switch, just like in your car. Or it could fire a small solid state timer which would drop a relay out after a minute or two. There are several ways to do it. Frank-in-Tallahassee/Pasadena
