720 john deere
jr55
06-23-2005 13:29:08
What does a 720 weigh?
Thanks
Dean
06-24-2005 04:33:19
 Re: 720 john deere in reply to jr55, 06-23-2005 13:29:08
My ES730DW with 4 front weights, 4 rear weights, flat fenders, 3 point, and unloaded 15.5s (obviously not stripped for pulling) weighes 9,200 - 9,400, depending upon the scales.
Dean
JonM
06-23-2005 20:41:41
My 720D with pony, nf rollomatic, 3-point and square top fenders and 15.5 tires is 8150 with 3/4 full tank of fuel.
JonM
Wes Miller
06-23-2005 20:00:43
i have a 720std. gas and it weights 7300 with me on it hase 18.4-30 dry no weights
720Deere
06-23-2005 16:37:19
My 720 diesel pony start weighs around 7800 with rollomatic frontend and no 3 point hitch. The tires are 16.9-38 which doesn't really add much weight. With the tires loaded with straight water to 75% (top of rim) it weighs right at 9500. Dad's electric start 720 w/ wide front weighs around 8000 with the 3 point removed and the same tires as mine.
I orinally had mine down around 7500 with 15.5 tires. That was before I added the elephant ears for the 3 point and a weight bracket or two. A gas tractor should weigh 200 to 400 lbs less than a similarly equipped diesel. A friend of mine pulls a 720 gas w/16.9 tires and rollomatic and he is right around 7400 with no additional weights.
Markuss
06-23-2005 14:04:07
My 720 Diesel standard weighs 9260 lbs....this is with loaded tires...I think most weigh about 7500 lbs.
