1935 D Fuel Tank Removal
Skyhawk Greg
06-23-2005 07:56:09
Good Morning. Feel a bit silly posting this message, but got home earlier today, at 4:30 in the morning, with a new-to-me 1935 John Deere D. It is in great operating condition, but the gas tank contains quite a bit of rust that needs to be removed before the tractor is run any significant amount. I am hoping to take it to a yearly gathering of antique vehicles this Sunday, so I only have tonight and Friday to get the tank off and treated. Saturday will probably be spent curing the sealant, and putting it back together. Since I cannot get to this until tonight after work, time is very limited, and I would like to get the tank out as quickly as possible. It will probably be quite simple, but being armed with knowledge always makes things go faster, and helps to avoid possible pitfalls. So, here's the question: What needs to be done to remove the gas tank from a 1935 D? Thank you. Greg
Skyhawk Greg
06-24-2005 07:39:38
 Re: 1935 D Fuel Tank Removal in reply to Skyhawk Greg, 06-23-2005 07:56:09
Thank you all for the help. It was extremely simple. Wasn't expecting that after working on the B. As mentioned yesterday, the gas tank was full of rust. Thought I'd post the results of what happened, and how it was achieved.
* Drained the old gas/mud colored mixture
* Removed the strainer bowl assembly from the tank.
* Put a 1/4" npt nipple with a ball valve in place of the strainer bowl.
* Pressure washed the inside of the tank as good as possible
* Poured 2 gallons of MEK into the tank. Had another person hold the other end of the tank and we sloshed it around. Let it sit about 5 minutes.
* Drained the MEK and poured in one gallon of Muriatic Acid. Filled the tank up the rest of the way with water. Let it sit 15 minutes.
* Drained the acid. * Turned the tank upside down and used a regular hose to flush the tank until the discharge water was clear and free of debris.
* Put another gallon of MEK into the tank and shoshed it around.
When the last of the MEK was out of the tank, the tank looked pretty much as good as new. It was completely free of rust, and a nice shiny metallic color. I let it dry about 1/2 hour, then put the regular strainer back in and mounted it on the tractor. Filled it up with gas, and it was a success. There was a little bit of water left in the tank, but it was caught by the strainer bowl before making it to the carburetor. After driving the tractor for about 1/2 hour, just removed the strainer bowl and dumped the water.
Maark
06-23-2005 10:11:40
There are two bolts under the hood towards the front and two at the back. Hood and tank will come right off. with a deadline as short as yours it might be easier at this time to remove the tank and shake and flush as much rust out that you can. You can remove the sediment bowl,get a short piece of copper tube,drill out the hole in the housing and insert the copper tube as a standpipe to get above the bottom of the tank. It will allow the sediment to settle at the bottom and only draw fuel without the rust chunks. About 1" will do.
Skyhawk Greg
06-23-2005 10:27:33
 Re: 1935 D Fuel Tank Removal in reply to Maark, 06-23-2005 10:11:40
Thanks Mark, good idea. Looks like taking the bolts out would not have taken much time, but the curing time required for the sealant certainly put a hold on the project for this weekend.
Mike M
06-23-2005 09:54:57
Haste makes waste --- Avoid Deadlines I have seen this way too many times,even seen someone putting decals on at the fairgrounds finishing up the day of the fair.
Skyhawk Greg
06-23-2005 10:03:26
 Re: 1935 D Fuel Tank Removal in reply to Mike M, 06-23-2005 09:54:57
Mike - Interesting that you said this. Since posting, I decided exactly the same thing! My mind is still a bit cluttered after 26 hours of almost continuous driving, but would still like any input on if there is anything to watch out for on the D's.
Bobl1958
06-24-2005 06:45:36
 Re: 1935 D Fuel Tank Removal in reply to Skyhawk Greg, 06-23-2005 10:03:26
The one thing I would mention, and you probably already figured it out is that on the D's you don't have brakes like most of the other JD's. You need to make sure your e-brake is working. You want to be careful taking it out of gear on a slope or it will take off and you won't be able to stop it as it won't go into gear rolling. Otherwise the D is a pretty simple tractor that is very forgiving. Certainly my favorite JD.
Skyhawk Greg
06-24-2005 07:26:57
 Re: 1935 D Fuel Tank Removal in reply to Bobl1958, 06-24-2005 06:45:36
Hi Bob, Yep, last night I did exactly what you said. Stopped the tractor on a slight grade to shift gears. It started rolling just a bit, and sure enough, wouldn't go into gear until the e-brake stopped it.
Since the D is your favorite, maybe you can help with another question. This D came with a stock exhaust stack that is in great shape. I would like to find a black (not chrome) exhaust stack that is straight through. I could weld the actual stack to one of those cast elbows if I knew where to find one. Seems the usual places that carry B parts don't have D parts.
Bobl1958
06-24-2005 09:14:47
 Re: 1935 D Fuel Tank Removal in reply to Skyhawk Greg, 06-24-2005 07:26:57
I think I have a cast elbow that you can have if you would want to pay shipping. Probably wouldn't be over $10.00 or so. The place I buy a lot of D parts is K&K Antique Tractor. Their phone # is 317-398-9883. Great people to deal with. My email is [email protected] if interested in the elbow. As for the gas tank, I would suggest that as soon as you have time to take it off and have a radiator shop boil it out. Most of them can line them with epoxy for you, or it's not hard to line them yourself. You will fight a rusty gas tank all the time if you don't.
Mike M
06-23-2005 11:06:09
I don't have alot of D experience. I do know about the excitement of a new toy ! I have an auxillary gas tank made up that I can wire on and run a (new to me) tractor so I can look for other problems that may need fixed while I have the hood and tank off. I also run a restored tractor this way before putting the hood on.
Skyhawk Greg
06-23-2005 12:00:56
 Re: 1935 D Fuel Tank Removal in reply to Mike M, 06-23-2005 11:06:09
Mike - That is how we ultimately were able to load the tractor where I picked it up. We used a small, clean gasoline tank similar to the ones used on portable generators. A hose was run from the hand held tank to the inlet side of the removed strainer assembly. This was a whole lot better than taking the chance of a fuel line plug up while half way up the ramps.
