Help retiming a 14T baler
Tim_in_IA
06-23-2005 07:29:17
Hi,
I am in the process of retiming a 14T balter. I have the front section timed so the press and the feeder teeth or arms are timed together, but now the needles are out of time. I understand that I need to remove the chain (rear drive?) that connects the knotters and needles to the front drive.
My question is, what is the best way to remove this chain? I don't have special chain tools. For the from chain I simply pulled the gear off as there was plenty of room, for the feeder arms I could just loosen the tensioner and have enough slack to make the adjustment, but for the rear drive chain it is so small and close to other components I just thought I would check to see how it is normally removed. The manual just says to remove it, doesn't explain how.
It is going to be 95 degrees today with full humidity so I just thought I would ask beforehand to keep the repair time to a minimum. Thanks!
Bob
06-23-2005 07:57:39
 Re: Help retiming a 14T baler in reply to Tim_in_IA, 06-23-2005 07:29:17
Locate the connector link in the chain, and remove the keeper, (or cotter keys if it's OLD) and separate the chain. NO special tools are needed to do that!
Darren
07-05-2005 20:21:10
 Re: Help retiming a 14T baler in reply to Bob, 06-23-2005 07:57:39
Bob or any other baler expert,
I recently broke the chain that controls the timing of the needles. I have replaced the chain but can't get the needles back in sync with everything else and I keep shearing pins. Is there a way with the chain off to line up the bottom sprocket with everything else to retimethe needles. Also, is there anyone that can help me find an owners manual? The local John Deere dealer says he can no longer get them.
Thanks
Tim_in_IA
06-29-2005 06:40:59
Just thought I'd post an update. I found the special link no problem and on my second try got the timing right. Had to figure out which side of the chain needed the tension to keep it in time, and since it was pulling counter clockwise the rear as viewing from left side needed the tension.
Also have a funny but not so funny twist. This baler seems to have a personality. After I got the timing right and went through a few cycles by hand, we ran some hay through and got a good bale or two. Then we took it out in the field to test, and on the third bale a u joint failed in the pto shaft! It is going to go down kicking and screaming before it actually does a days work. I had mentioned to my dad that the pto angle looked a little extreme, but he thought it was fine. Either it wasn't or it was just an old joint. We'll get the u joint replaces and raise the pivot point where the two pto pieces come together so that it is more in line. That is the fun with old equipment :).
Tim_in_IA
06-23-2005 08:00:49
Okay, so one of the connectors will be special and easy to seperate. This is great news. Thanks much!
