Three basic questions - model 60
Tom in Montours
06-23-2005 05:46:35
As I work, read, and learn more about my tractor I come up with more "basic" questions and am turning to you folks for answers.
First - I'm trying to get an idea of fuel burn rate for my 60. I figure I'm burning about 2 gallons a running hour, does that seem close? That's working the machine mowing grass or running the loader. Running the loader I'm working the tractor at about 700-800 rpm. Pulling the mower I'm running rated speed.
Second -- I can't keep the clutch cover on. I have all three tabs inside the drum. One I replaced and it is tight, but the cover still loosens itself and flies off. Any ideas on how to stop that? Should I be using some silicone to hold it?
Third -- I had to replace my clutch drive disk (the expensive balanced piece). Every since I put the clutch back together it seems it won't hold a good adjustment. I'll adjust it within spec and within 5 hours or so it needs adjusted again. It doesn't slip -- it just gets too loose, requiring very little, if any, pressure to "snap" in.
I really appreciate your time and patience as I learn about my machine.
TOM
P.S. I really love my 60.
F-I-T
06-24-2005 13:46:47
 Re: Three basic questions - model 60 in reply to Tom in Montoursville, 06-23-2005 05:46:35
Tom:
We had a '48 "A" with hi-comp aluminum pistons in it and it would burn more like three gal/hr, and as much as 5 if the 3-14's were in clay. Now you know why we were so excited over the 70 Diesel's economy of 2 gal/hr with 4-14's. Back then at 32C gasoline versus 18.4c diesel, we were saving nearly $1.25 an hour just on fuel. Corn was 88 cents a bu. wet, so it was a decent improvement. After 3,000 hours the tractor was paid for in fuel savings. Now you know why the diesel version of the 70 sold as many as the gas even though it had a significant price premium and was offered for sale for only half as long a time.
On the clutch cover coming off, sometimes as the clutch parts wear the ends of the t-bolts touch the cover. This will pop the cover off with regularity and will not be fixed without removing some of the wear and play, or grinding some of the length off of the t-bolts (they probably have some wear on their shoulders which make them effectively longer when engaged). I would not attempt to glue it on with any type of adhesive.
I would think that no matter where on the crankshaft the clutch driver disk was located, the clutch pack would be the same thickness, so creeping on the splines seems to me to be an unlikely cause. I'd think that it is a combination of wear in all the parts to the point that onetime you set it with the dogs sitting against the close side of their oblong hole, only to have them relax to their loose side of their oblong hole later. Then you adjust it again and the t-bolts notches in the shoulders are in a nice snug bind only to find their way into a sloppy notch after you adjust it.....so it goes, on and on.
You might try this. The next time you find the need to adjust it, don't disengage the clutch. This way every thing is pretty much shaken into its tightest position which is evidenced by all the extra play. Just shut the tractor off and let it all coast to a stop. Kick the transmission stick into neutral after it's stopped and set the brake. Now you can adjust the three nuts one castellation and try things again. It might work and then again it might not. I have bought myself a few extra months this way until I had time to gather all the parts together for a decent pulley overhaul. It doesn't cost much to try.
You might also want to double check the driver on the splines and the crankshaft endplay.
Frank
buickanddeere
06-23-2005 08:24:22
Is that new driver sliding down the crank splines farther with usage?
06-23-2005 18:16:30
 Re: Three basic questions - model 60 in reply to buickanddeere, 06-23-2005 08:24:22
I thought that it might be sliding down the splines. The splines on my crankshaft look very good and are well defined.
I'll keep tightening the clutch to spec and will check what Mike is recommending.
Solving the clutch cover problem is a blessing in and of itself !
Mike M
06-24-2005 09:43:03
 Re: Three basic questions - model 60 in reply to Tom in Montoursville, 06-23-2005 18:16:30
So was your cover indexed wrong ???
06-26-2005 11:07:47
 Clutch cover in reply to Mike M, 06-24-2005 09:43:03
Mike,
I checked over the clutch cover and there is not a ridge on it. It is completely smooth all the way around. I tried to get it on nice and tight yesterday, but after 20 minutes of mowing it came off. Only problem was I didn't see it until the mower ran over it. So - now I'll be getting a new one, and a new blade for the mower also. I didn't have a good day yesterday.
I did adjust the clutch the way Frank said to do. It is working so far. Has a nice tight snap to it right now. If it continues to be a problem I guess I'll have to splurge on all new clutch parts.
I've been trying to determine my burn rate. I'm guessing around 2gph is close, especially in the heavy tall grass when the mower is really working the tractor. I brought her back to low gear last evening as the grass was super tall and the tractor was working too hard, even in second.
I'm also going to check and see if my adjustment bolts are hitting the cover. I think that is a big possibility.
I'm sure I'll have more questions soon, and I appreciate your time.
I've got to adjust the wheel bearings this week. That seems like a straight forward job.
Thanks again.
TOM
Mike M
06-23-2005 06:11:29
On the clutch adjustment,did you put in any new facings ? Maybe they just need seated in ? They should get to where they don't need adjusted much after a few times. On that clutch cover are you indexing the flatened portions with the adjusting nuts as the ribbed area is to pop under the clips so it holds tight.
06-23-2005 06:18:59
 Re: Three basic questions - model 60 in reply to Mike M, 06-23-2005 06:11:29
Hi Mike,
Thanks for your response. You've helped me quite a bit recently. I did not put new facings in the clutch. The JD parts man said mine were still "serviceable." I've probably adjusted it about 3 times since I put the new drive disk in.
I didn't know about indexing the clutch cover. I'll check that as soon as I get home tonight.
I bet that will make a huge difference!
Tom
Kevin L.
06-23-2005 06:49:27
 Re: Three basic questions - model 60 in reply to Tom in Montoursville, 06-23-2005 06:18:59
I know the clutch cover only fits on in three indexes, one thing to look at, is the metal at the clips, sometime they get bent up and go over the clips and not under as they should be and the over helps push the cover off. also think theirs little half moons of metal missing that are the indexes but can not remember if their at the clips, the adjusting bolts or giude pins.
think the 2 gallons or a little less per hour is inline with my 60 when using it for cultivating, but I know it loves and/or uses more when pulling the breaking plow and subsoiler.
Mike M
06-23-2005 06:33:31
I would think it should be holding adjustment by now ? Are your cotter pins going into the castle nuts so they hold,I've had some I had to put washers under them to bring them closer to the cotter pin holes.Maybe that driver is working around still causing some trouble ?
Did you ever have your pulley off all the way and check for broken/cracked toggle dogs or the operating sleeve dowel pin and hole getting worn out that keeps it from rotating ? All of these can make your adjustments not hold good at all.
