Mark. I can help ya a bit as far as what you question as a 6 and 12 volt ignition on that 720 gas tractor. If its what I suspect youre talking about, its all a regular 12 volt system EXCEPT that the coil is only rated for 6 volts. THEREFORE, to reduce the 12 volt battery voltage down to 6 volts necessary for the coil, theres a series voltage dropping ballast resistor (bathtub style ceramic block) located in the circuit between the ignition switches IGN output and the coils primary input terminal. It serves as a voltage divider dropping 6 volts across it leaving 6 at the input of the 6 volt coil. Nowwwww wwww to yield a hotter spark when starting (cuz cranking motor drags battery voltage down) the starter switch has an extra lil terminal thats hot when the starter switch is engaged and it sends unballasted battery voltage direct to the coils input ONLY WHILE CRANKING. It, therefore, by passes the ballast resistor while cranking so the coil sees more voltage for a hotter starting spark. Then when she starts and the starter is disengaged, the coil sees the normal ballasted input voltage (via the series ballast resistor) of around 6 volts. Long ago I wrote an entire article for Green Magazine covering Ballast Resistor Circuits, e mail me if you want me to dig out the draft. Clear as mud?? Post back any questions John T Nordhoff in Indiana
