213 flex head to ridgid for wheat?
HA in Oh
06-23-2005 03:46:08
Posted on combine board, need your help. Thanks.
Ray
06-23-2005 04:38:50
 Re: 213 flex head to ridgid for wheat? in reply to HA in Oh, 06-23-2005 03:46:08
You have to bolt it in the solid position for wheat,otherwise it will bunch up.There should be 4 or 5 bolts about 4 inches long and a flat washer about 3 inches in diameter to keep it from
flexing.
HA in Oh
06-23-2005 07:27:19
 Re: 213 flex head to ridgid for wheat? in reply to Ray, 06-23-2005 04:38:50
Where do the bolts go, someone has welded plates on the bottom. Old owner ran only beans and corn.
Mike Aylward
06-23-2005 10:05:31
 Re: 213 flex head to ridgid for wheat? in reply to HA in Oh, 06-23-2005 07:27:19
HA, if memory serves me right I think you will need 7 bolts, nuts and large washers for your head. Usually it is one every two feet plus one for the end. They go through a hole in the arm that supports the sickle up through the floor pan of the head. If they have a half inch longer carriage bolt available it is easier to get them in there and tightened. Hope this helps. Mike
