NOISE IN HIGH RANGE OF A 37A
BUBSDAD
06-22-2005 19:51:15
ANY OLD JOHN DEERE MECHANICS OUT THERE THAT CAN TELL ME WHERE TO LOOK FIRST FOR A GROWL NOISE IN HIGH RANGE ON A PULL, SEEMS TO GO AWAY WHEN SLOWING DOWN. TRACTOR IS QUIET IN LOW RANGE.
THANKS FOR ANY HELP
Mike M
06-23-2005 07:27:22
 Re: NOISE IN HIGH RANGE OF A 37A in reply to BUBSDAD, 06-22-2005 19:51:15
The right hand bearing on the input shaft which is in the reduction cover is known to go bad.You can replace it fairly easy,it may not change much in the noise department? On one that old more than likely all the trans. bearings are loose if not bad,gears and shafts worn.Can't hurt to open it up and check it out you may be amazed at what you will find once you go looking.
