JD 2940 HiLo and hydraulic problems
HMC
06-22-2005 17:06:46
I have a 2940 and it has started to stop pulling under load in Lo gear. It does good in Hi until it gets hot, then it wants to jump back to Lo. It is like it hits a neutral spot at times and I can hear a slight, deep whistling noise. Now I hear the noise in Lo gear as well, but if I pull it down in Hi and hold it, it pulls good and doesn't slip. Another seperate problem that I have noticed before this incidence is once hot, the hydraulic pump works well at high RPMs, but once idled down, the pump seems to be starving for fluid. I would appreciate any help!
cannonball
06-23-2005 04:39:17
 Re: JD 2940 HiLo and hydraulic problems in reply to HMC, 06-22-2005 17:06:46
you need to check your screen and change your fluid and filter...if screen is not dirty then you probably have an internal leak....have nice day may god bless
HMC
06-23-2005 07:40:33
 Re: JD 2940 HiLo and hydraulic problems in reply to cannonball, 06-23-2005 04:39:17
I will try that this afternoon. Where is the screen located? I assume that it is near the filter. Thanks.
Mike M
06-23-2005 11:11:18
 Re: JD 2940 HiLo and hydraulic problems in reply to HMC, 06-23-2005 07:40:33
Can't say for sure on that model but they are almost always near the lowest part of the trans. case set in there crossways. Look for a big round plug 2" ? maybe on the side. Some have a square hole in them for a 1/2" breaker bar.
HMC
06-23-2005 13:33:06
 Re: JD 2940 HiLo and hydraulic problems in reply to Mike M, 06-23-2005 11:11:18
I know exactly what you are talking about now, thanks.
