G .090 piston rings
Rudy in TX
06-22-2005 16:00:44
Does anyone know if .090 rings are available for a styled G from JD? If so do you have a part number? My parts book and my local dealer show only .045 available from JD. If I can't get them from JD then who would be a source?
Rudy in TX
06-23-2005 10:52:31
 Re: G .090 piston rings in reply to Rudy in TX, 06-22-2005 16:00:44
Thanks for the help everyone, I should be able to find them with this help. Thanks again!
Earl- IL
06-23-2005 07:59:16
Rudy, For your Deere, 2C 7842 +.090 is the correct Hastings ring set for all 1/4 rings 5 per piston. 1-800 776-1088 This is the phone # direct to Hastings. If you can't find a parts store that sells Hasting. Most machine shop sells Hastings because they are our last and only USA Co. that are making the ring sets .There are other independents that make up to 24" bore.Earl In Illinois (email if you need help)
Ben.So.Tex
06-23-2005 04:52:29
I got a set of 90 for my 60 from Industrial engine's in San Antonio. Take your pistons with you if you go this route. Good Luck Ben
40 JD G
06-22-2005 19:47:30
I just bought new .090 over rings for my G from JD, they are not JD rings, the parts man ordered them from a different catalog.
Bob
06-22-2005 17:42:34
Try Dave Otto.
