Advice please! JD500C stabilizer piston #:)
Dave Zimmerman
06-22-2005 10:33:29
Can anyone enlighten me as to how to dissable the stabalizer piston on a 1975 JD500C? I was able to remove the spanner nut but the remaining threads just spin and still nothing comes apart. The service manual is not too specific as far as this goes!
Tom in central Pa
06-22-2005 18:06:56
 Re: Advice please! JD500C stabilizer piston #:) in reply to Dave Zimmerman, 06-22-2005 10:33:29
As WTW says, I would also add, Get your new packing kit. In the kit there should be a plastic ring, flat on the inside, rounded on the outside. After you push the head down into the cylinder, and remove the wire ring, insert the plastic ring into the barrel groove where the wire ring was. Then pull out the head, ram and piston. The plastic ring is to keep the packing rings from hanging up in the ring groove as you remove them.
WTW
06-22-2005 10:40:27
Not sure what type of cylinder you are working with but, sounds like you have male threads exposed after removing the spanner nut at the end of cylinder barrel. If this is the case the threaded part will have to be pushed down into cylinder bore until a round wire snap-ring becomes exposed. Remove wire retaining ring and then pull cylinder apart. Good Luck, DW
