720 PTO keeps running after disengaging
dak
06-21-2005 23:28:26
Ihave a 1958 720 Iuse it to brush hog and a other PTO equip on it . My problem is the pto keeps runnimg even when I disengage it. very dangerous. How do I fix it and what is wrong and how hard is it to do any suggestions appreciated.
dirtjockey
06-22-2005 06:13:31
 Re: 720 PTO keeps running after disengaging in reply to dak, 06-21-2005 23:28:26
Is it the PTO brake you are talking about or does the main clutch pack not release or is too tight?
dak
06-24-2005 23:22:59
 Re: 720 PTO keeps running after disengaging in reply to dirtjockey, 06-22-2005 06:13:31
I am not sure what is wrong I can tell you it is not just drifting I tried to see if I could stop the brush hog pto shaft and you could not stop it .
Dirtjockey
06-26-2005 08:16:38
 Re: 720 PTO keeps running after disengaging in reply to dak, 06-24-2005 23:22:59
Have you adjusted anything lately on it? The clutch pack is not hard to set. If it has 3 point you have to remove the elephant ear and the small cover with 3 bolts/ studs and adjust. If you haven't adjusted anything lately and it just started doing this then you might have had a failure in the pack. or the pump brought something up in to the pack. they are not very complex at all.
