1946 John Deere H generator inop.
Craig Lyon
06-21-2005 20:35:23
I just purchased a '46 H and the generator won't charge the battery. All of the connections are clean, bright and tight. It is a three brush generator with a cutout. Any suggestions?
John T
06-22-2005 06:48:39
 Re: 1946 John Deere H generator inop. in reply to Craig Lyon, 06-21-2005 20:35:23
Craig, You could have something simple wrong, but heres how I would diagnose it to see it its minor or a bad ground or else a Generator or a Cutout Relay or Light Switch or another problem:
Since you claim it has a cutout, I will proceed based on that, but if it had a 3 or 4 wire full fledged Voltage Regulator, post back cuz my troubleshooting procedure will be somewhat different. Are you sure the ammeter works??? If you turn on lights does it swwing over to discharge?? Does it ever move??? If the ammeter were stuck but still a closed circuit, it could stil be charging which measuring battery voltage from not running to fast RPM could indicate or even if the lights got noticeably brighter from idle to fast RPM.
HAVE YOU POLARIZED THE GENERATOR??? DO THAT TO INSURE N BE SAFE
TROUBLESHOOTING NON CHARGING ON A CUTOUT RELAY SYSTEM
1) Make sure the belt is good n tight.
2) Insure a good ground connection to the Generator and Cutout Relay and Light Switch. If in doubt, run a ground wire direct from the batterys gtounded post to the Gens frame and the Cutout Relay mounting and the light switch where it bonds to the dash.
3) Insure the BAT side of the Cutout Relay ALWAYS READS HOT BATTERY VOLTAGE. It has to for the gens output to get to and charge the battery. The BAT side of the cutout relay wires to the load side of the ammeter and BOTH sides of the ammeter MUST ALWAYS READ HOT BATTERY VOLTAGE or else its miswired or bad/open. Until you get hot battery voltage on BOTH sides of the ammeter and the BAT side of the Cutout Relay, no use in going any further.
4) The battery must be capable of taking a charge !!!!! Insure electrolyte is above all the plates and that no cells appear gray or milky. Have a shop load test it if any doubt.
NOW LETS SEE IF ITS A GENERATOR, OR THE CUTOUT RELAY, OR A LIGHT SWITCH PROBLEM. Do this AFTER you insure the good grounds and connections as listed above. If in doubt, remove, clean n wire brush and re attach each n every Gen and Cutout Relay and light switch and ammeter connection!!!!! You gotta have good connections n good grounds !!!!! !!!!!
5) Fire her up and temporarily dead ground the Gens Field post to it case n see if she charges then????? If so, the problems EITHER the light switch isnt well grounded,,,,, ,,or the light switch is inoperative,,,,,or theres a wire missing/open from the Gens Field post up to the light switch. ON LIGHT SWITCH TYPE SYSTEMS I ALWAYS INSPECT THE LIGHT SWITCH N ITS GROUND AS ITS A POSSIBLE CAUSE FOR NON CHARGING
6) If she still dont charge even with the Gens Field post grounded, leave it grounded and momentarily by pass jump around the Cutout Relay by hooking its BAT and GEN terminals together n see if she charges then???? If so, the Cutout Relay is bad or miswired or not suitable for your ground (+ or -). BAT side to ammeters load side, GEN (or ARM) side to the Gens Arm post
7) If no charge even with the cutout relay by passed and the Gens field grounded, you have essentially by passed operations n if she still dont charge ASSUMING ALL THE PRELIMINARIES ABOVE ARE ALL GOOD, its Generator problem.
8) MOTOR TEST: Unhook the Gens belt and ground its Field to its case and apply hot battery voltage (like from the BAT side of the cutout relay) direst to the Gens Armature post and it ought to spin. Then unground the Field and it ought to spin a lil faster. Usually if it does both those things its good.
9) The most commoin problem for a non working Gen is the brushes are worn down too low or the brush hold down springs are stuck and arent pushing down tight on the brushes. Try to clean and WD 40 the brush hold down spring assemblies so they snap up n down to hold the brushes tight. Also try n clean any residue off the Gens copper commutator bars. Then if the brushes arent worn down too low but she still dont work, it could be an open field or a bad armature or other problems.
Post back your findings and any more questions, let is know.
Good luck n God Bless
John T Nordhoff in Indiana
Mike M
06-22-2005 07:16:00
 Re: 1946 John Deere H generator inop. in reply to John T, 06-22-2005 06:48:39
John T ; While we got your attention on 1946 JD H gen. problems. I have one that everything is new,or rebuilt,grounds should be clean as paint was removed from these surfaces apon assembly. Problem is on initial start up it will not start to charge unless I use the foot throttle and run the engine faster than the hand throttle will allow. It will then kick in and charge and seem to work normal from then on out. Is there and adjustment to try ? Is this maybe "normal" and I am just too fussy ?
John T
06-22-2005 07:26:01
 Re: 1946 John Deere H generator inop. in reply to Mike M, 06-22-2005 07:16:00
Mike, that has to do with EITHER the cut in voltage setting on the Cutout Relay or else the RPM of the Generator (belt or pulley problem or try a smaller diameter Gen pulley) or the condition of the Gen and VR (or even grounds or connections) in general. The Cutout Relay, regardless if inside a VR or a stand alone 2 wire devive, closes when the Gens voltage exceeds that of the battery and thats an adjustable variable and it then, of course, opens back up when its less as when the tractors off so the battery dont reverse discharge through the Generator.
As far as making any air gap or spring tension adjustments on the relay to change the voltage at which it cuts in/closes,,,,, ,,,that makes me nervous and I dont get into it over the net, but you might check the belt and its tension and insure the Gens pulley isnt cupped out or possible swap it out for a smaller one.
Other then that I wouldnt worry so long as she kicks in n charges at RPM.
John T
Mike M
06-22-2005 07:41:31
 Re: 1946 John Deere H generator inop. in reply to John T, 06-22-2005 07:26:01
I have a stand alone cut out and have the factory light switch controling high and low charge.Pulleys are all what JD put on when new,anyones guess if they were even right then ? I have never monkeyed with the cut out for fear of making it worse.Maybe I'll swap it out from one off my A,or B and try it.
John T
06-22-2005 07:48:36
 Re: 1946 John Deere H generator inop. in reply to Mike M, 06-22-2005 07:41:31
Assuming the belt n pulleys are all good, the only things left are the cut in/close voltage setting on the cutout relay (which I also wouldnt like to monkey with lol) and if the light switch has a good to dash ground and its contacts are all good n clean n carbon or residue free. For the heck of it I would try her with the Gens Field dead grounded to its case n see if she acts better then??? If so, I would suspect a poor quality switch ground or its wiring or its contacts are burned or carboned or have residue versus a cutout relay problem as we earlier suspected.
Ler er hapn capn
John T
