3020 pto switch
anderson farms
06-21-2005 20:28:46
I need to take my 540 shaft out and do a little grinding on it, a friend hooked up a disc mower and dinged up 3 of the splines and now my pto off my rotary mower won't slide all the way up and engage so I guess I need to sand those dings off? Any help would be nice. Thanks guys
msb
06-21-2005 21:00:22
 Re: 3020 pto switch in reply to anderson farms, 06-21-2005 20:28:46
Why not use a small angle grinder and leave the shaft in place?If that is not possible,remove the snap ring with a pair of plier sand pull the shaft out.You will probably want to put the 1000 RPM shaft in until you get the nicks ground down.You may have to try different locations of the splines when reinstalling to get the shaft all the way back in.Have the 1000 RPM stub shaft by your side,ready to install it, when removing the 540 shaft to keep from losing so much transmission oil.
