2010 - Can't get the remote valve off
Dave / Believer
06-21-2005 17:45:53
1964 2010, I have both hydraulic lines off, one bolt off, one bolt (in a slot instead of a hole) backed all the way out(will not come out - it hits the steering support), linkage removed - the valve will lift straight up but will not come out. Can anyone give me some help? I figured the slot for the mounting bolt rather than a hole is there for a reason - the valve will not rotate so it can come off the bolt.
Thanks -- Dave / Believer45
Believer45
06-26-2005 20:47:59
 Re: 2010 - Can't get the remote valve off in reply to Dave / Believer45, 06-21-2005 17:45:53
Thanks for the replies, I really appreciate the help.
The valve leaks out where the spool slides in and out in the valve body at a rate of a quart a minute or so (ballpark guess, probably low)any time the tractor is running, I am evidently trying to remove the bracket as well as the valve. I thought the plate on top of the bracket (pedestal?) was part of the valve. I will tighten things back down and try just the valve - I am taking it to a local hydraulic shop to see if they can go through it and take care of the leaks. As it is, I cannot use it at all until the leak is fixed.
Thanks again for the help.
Dave / Believer45
TylerARK
06-23-2005 05:57:19
I think msb has it right but I do know that the procedures dont always work from tractor to tractor. We just tore down a 2010 and it wasnt hard to get the remote valve out , But we cheat, we had all the other stuff taken out of the way because we werent going back together with it, lol. I have the remote valve kit listed on ebay now if anyone is interested.
Tyler
HTR
06-22-2005 13:01:54
If your 2010 is a 1964, there are three bolts in the round base. There should be two holes with bolts, and one slot with a bolt.
msb
06-21-2005 21:38:26
Are you attempting tp remove the base too.I don't understand the slotted bolt hole. Service manual says to also remove the cowl right side panel on serial number 29001& up. Remove the two mounting cap screws from the base of the valve--Then --.up to ser # 21885 : When removing the valve housing first lift upwards until the oil tubes in the base are free of the bores in the clutch housing and then pull assembly to rear while freeing line connections
ser# 21886&up: Lift valve from mount while freeing line connections.Remove mounting adapter from clutch housing bore.Hope this helps.Its been a LOOOOO NNNNNG time sice I removed on of those valves
