4020 Won't Rev up
Stephens
06-21-2005 16:16:58
I have a Diesel 4020 (66) model. When you pull down on the throttle, the rpm gauge goes up like it is reving up to proper speed and engine does rev up some, but not like it is supose to do. I have another 4020 that I have compared the position of the throttle linkage with. It is moving the likage on it just like my other 4020. I can move the linkage on the fuel pump by hand past where it should be and still no power. This thing runs enough to drive around and work, but has no power. Only 1/2 the rpms it should have even though the rpm gauge says it is running like it should. What's up?
Jon (IN)
06-22-2005 10:35:11
 Re: 4020 Won't Rev up in reply to Stephens, 06-21-2005 16:16:58
I can't say that I am too experienced with the diesels and the other guys suggestions about the pump sound like good ideas, but I have learned more than once not to look deeper into the problem than what may be needed....Check your filters(air and fuel) and the fuel suppply lines. If you don't have a good supply of both, she ain't gonna run with much power.
Good Luck...
msb
06-21-2005 21:08:23
Probably an injection pump that needs rebuilt.Remove the return line at the rear of the injection pump( it goes from the pump up to the top of the injectors) and remove the 90 degree fitting in the pump.Start the engine and see if it revs up as it should.If so,get the pump rebuilt by someone who knows what they are doing.
If that doesn't do it, replace the fuel filters and blow the lines out clear back to the fuel tank.
txgrn
06-22-2005 05:16:36
 Re: 4020 Won't Rev up in reply to msb, 06-21-2005 21:08:23
It should be a Roosa Master pump. On that pump there is a metal plate on the side (about 1" long and .5" high as I recall) with 2 flat head machine screws holding it in place.
Loosening the screws and allowing fuel to run out while attempting to run full rpm's does the same thing. If it clears up with the plate loose pump needs the works.
Now on the tach; if it is reading full rpm's and you know it is not running full rpm's that is a different problem. Can trouble shoot a system running less than actuals. Don't know what to say about above actuals except to get another tach.
Mark
Stephens
06-24-2005 10:24:54
 Re: 4020 Won't Rev up in reply to txgrn, 06-22-2005 05:16:36
Thanks, it reved up when I loosened the plate that has the 2 screws. Now I want to send this pump off to get rebuilt. I going to put the pump from my other 4020 on this tractor, because I need to use the loader that is on this broke tractor. IT says to take time it at #1 cyl at TDC. How do I know when #1 is at TDC? I have found the timing mark on the flywheel, just not sure how to know when #1 is on compresion stroke. Do I have to pull the Valve cover?
thanks
jason
