'49 B wheel hubs
in too deep
06-21-2005 14:07:03
I just bought a model B and I need help getting the hubs off the rear wheels. I took the collar/clamp off with the bolts provided, but I can't budge the wheel itself. Right now i'm trying eye bolts through the wheel hooked to a three-arm puller, but all that's doing is opening up the eye bolts. I need to get the wheels off so I can begin freeing up the differential and/or trans. Hence, my name "in too deep" Any help would be great.
Chris in northern Illinois.
MITCHP
06-22-2005 10:38:50
 Re: '49 B wheel hubs in reply to in too deep, 06-21-2005 14:07:03
I HAD THE SAME PROBLEM A COUPLE MONTHS AGO, ONE THING THAT HELPED WAS PUTTING P-B BLASTER AROUND THE HUB AND SPLINES. I HAD A GUY TRYING TO GET THEM LOOSE FOR ME AND HE FINALLY GOT A BIG HAMMER AND STARTED POUNDING ON THE HUB UP CLOSE TO THE CENTER PART OF THE WHEEL, THEY FINALLY POPPED LOOSE, AND YOU WILL KNOW IT TOO, SOUNDS LIKE A SHOTGUN GOING OFF. INSTEAD OF EYE BOLTS, YOU MIGHT TRY SOME THREADED RODS THROUGH THE HOLES IN THE WHEEL CENTER, WITH A PIECE OF THICK STEEL ACROSS THE END OF THE AXLE, DRILL HOLES IN THE STEEL AND PUT THE RODS THROUGH THEM, AS YOU TURN THE NUTS, IT WILL PULL THE WHEEL, WE DID THAT WHILE HITTING THE HUB, IT WORKED, BOTH WHEELS CAME OFF. BE CAREFUL NOT TO BUST THE HUBS, I WAS AFRAID THAT GUY WAS GONNA BREAK MINE BUT WE WERE ABOUT OUT OF OPTIONS. HOPE YOU GET EM' BROKE LOOSE.
in too deep
06-22-2005 07:24:03
Thanks Pat, we'll be in touch. I'm about 50 miles straight south of Rockford. About smack dab between Rochelle and Dixon.
Pat Browning
06-22-2005 05:30:39
Chris -- do you have access to June issue of Green Magazine? Dan Brotzman authored an article that was meant to provide relief for a problem like yours. The puller you are trying to use isn't up to the job. Perhaps I can e-mail the scheme to you if you give me a shot by retrun mail. [email protected]
Dave in SV
06-21-2005 19:50:58
Where abouts in northern Illinois are you?
