Clutch jerking
Glen E.
06-21-2005 13:07:47
I have a '50 B. It is impossible to engage the clutch smoothly. As you ease it in, it grabs and the tractor jerks and lurches. Is this adjustable or is it time for a clutch?
Mike M
06-23-2005 06:25:07
 Re: Clutch jerking in reply to Glen E., 06-21-2005 13:07:47
I have had some that were clean just glazed over,metal parts shine like a mirror,just knocked the shine off with some sandpaper and it went away.I like to sandblast the face of all the metal parts I can pull out. Some tractors never will be "just right" I had a model 50 that I never could get the clutch to work as good as my others.I got it to where I could run it ,but dad always had trouble with it.
buckeye al
06-21-2005 13:43:31
Generally this is caused by oil & dirt on the facings, especially the one behind the clutch driver. Very pronounced in the late B's. Usually a good cleaning of everything with some volatile solvent will make it straighten up & fly right.
Make sure you carefully inspect the floating disks for cracks, fraying and/or any damage. I replace these if there is any visible damage at all. Same with the release springs.
While you're this close, remove the pulley, assure the oil returns are open, grease the toggles, the clutch dogs and clean & re-pack the roller bearing.
Not a bad job.... unless your right wheel is in close & stuck.
Good luck.
