620 and 1219
JDJACK
06-21-2005 07:59:57
I have a jd 620 and would like to pull my 1219 haybine behind it, don't think that the hitch adaptor will fit on the draw bar. And the pto shaft is off set from the draw bar. Can the drawbar be swung over to make this line? Anybody else use a 2 cylinder to pull a haybine.
Bimmer
06-21-2005 15:10:30
 Re: 620 and 1219 in reply to JDJACK, 06-21-2005 07:59:57
Our family farms are run almost entirly with two-cylinders, we cut most of our hay with a 720 with the heavy duty drawbar, which fits the adapter for our 1209 (slightly earlier, but mostly the same) well, the 620's lighter bar won't make for as good of a fit, but once you move it over it should work fine. For PTO work the drawbar should be set all the way out, lined up with the pto shaft, which i think requires the bolts to be moved over one hole from where they are when the drawbar is straight. The bar should be turned up or down to line up the shaft from the machine as straight as possible as it will normally be pulled, or as makes the machine run best
rla
06-21-2005 08:58:12
It will work move the draw bar...
