John Deere Killefer Co. Subsoiler ??
farmboykj
06-21-2005 06:24:32
I recently discovered a John Deere Killefer Co. subsoiler in my grandfathers barn that had never been assembled. The tag says it is a model 22-01. I am wanting to assemble this unit and use it in an area of a field that I have. It had the original manual wired to it but the years have taken its toll on it and it cannot be read. I downloaded a parts manual off the JD website and it appears that all the parts are there and I assembled. Can this unit be used on a modern day 3 point hitch?? The parts manual shows an extra bracket that is needed for the 800 hitch, which mine doesn"t have. I put it on my 3020 but I don"t see how the shank locks into the vertical position for field use?? Everything pivots on the brackets leading to the toplink. There is a pin that can be inserted for road travel to make the shank fold up under the rear of the tractor. Has anyone had experience with these or could point me in the right direction?
Chris Barten
09-19-2006 14:55:44
  John Deere Killefer Co. model 40 in reply to farmboykj, 06-21-2005 06:24:32
hi i found a john deere Killefer it says its a model 40-1 i cant figure out what it is and what it is. can tell me about it is it antique?
JDVan
06-21-2005 09:15:53
 Re: John Deere Killefer Co. Subsoiler ?? in reply to farmboykj, 06-21-2005 06:24:32
I have a couple different Operators Manuals for a model 22 & 22A Pan breaker. OM-K38-354 No 22 for No 800 Hitch (includes Parts Catalog) and OM-K35180 for 22A Sub Soiler. It appears the 22 was intended to be used spcifically with the 800 hitch(with mast bracket) and the 22A with both the 800 hitch(with Mast bracket) and a conventional three point hitch. The 22A manual describes a connection to a 3020.
The primary difference between the 22 and the 22A is the RH and LH Mast. The 22 Mast has three holes on each side whereas the 22A has four. Under normal operation with an 800 hitch Mast bracket adapter installed the frame rotates under load until it hits the Mast Bracket(P819A) and that is it"s normal working position. On the 22A there appears to be two bolts that go through the masts with spacer sleeves that act as a stop for the frame instead of the Mast Bracket.
But it appears to me that a 22 could be made to work with a 3020 top link by inserting a 3/4" x 4-1/2" bolt and correct length spacer sleeve in the second hole down and a ball and top link pin in the top hole for the 3020 top link attachment. The bolt and sleeve would act as the stop when the frame rotates under load. Now whether one bolt and sleeve has adequate shear strength comes into question since the 22A has two. Worst case one could drill another 3/4" hole in each side and insert a second bolt and sleeve. My guess is that the 2nd and third bolt holes on each side allow the 22A to be used with either a P819A Mast bracket or a 3020 Top Link. So the hole spacing for the second and third 3/4" holes on the Mast have specific positions. I suspect the bolt through the second hole down might want to be a grade 8 bolt protected by a sleeve. Ideally one wants the shear bolt(very bottom bolt in the frame/standard interface) to shear first. The sleeve(s) should be the same length as the Inner Bearing Part # Q30674. Hope this helps.
farmboykj
06-21-2005 13:12:08
 Re: John Deere Killefer Co. Subsoiler ?? in reply to JDVan, 06-21-2005 09:15:53
Wow, thank you for all the good information. This helps out a lot. I will try your suggestion and see if I can get it to work.
Thanks again
