Possible to determine year on war time 'A'?
A 420C
06-20-2005 20:54:04
I have what is guessed to be a 43'-44' A and the steel serial plate has rusted off. Any other ways to determine model year by casting #'s or anything else?
By the way I'm new here, I have the 'A' listed above and a 56' 420C crawler loader, which will be paid off soon I hope. I am sorta new to this but I'll be around on here, mainly with lots of questions about this 'A'. Thanks!
Will P
06-20-2005 21:02:09
 Re: Possible to determine year on war time 'A'? in reply to A 420C, 06-20-2005 20:54:04
Cast frame? Angle iron frame? pressure radiator cap? non pressure cap?
Will P.
43A
43B
49G
51G
A 420C
06-21-2005 15:02:32
 Re: Possible to determine year on war time 'A'? in reply to Will P, 06-20-2005 21:02:09
It has the cast iron frame, and small radiator cap
Will P
06-21-2005 18:15:04
 Re: Possible to determine year on war time 'A'? in reply to A 420C, 06-21-2005 15:02:32
That would be serial number range of 523600 to 542626. The 43 model year is broke into two sections. The A was killed for 7 months in 43. The first half was angle iron frame with big cap. The second half was 522600-524422 with cast frame with small pressure cap. As you can see, the last little bit of 43 had a cast frame and pressure cap. Deere also started the PTO flipper at serial number 523600. So, if you have a flipper guard on the PTO and a cast frame with a small pressure cap it would be in the range of 523600-542626. The ending serial number for 43 is 524422. Your tractor could be one of the last 1322 made for 1943 or one of the almost 20,000 made for 1944. I would bet that it is a 1944. Hope this helps.
Will P
43A angle iron frame non pressure cap
43B cast iron frame non pressure cap
49G
51G
