Conflicting Information
Dave from Texas
06-20-2005 10:51:28
Valuebilt Tractor Parts show the water pump to be the same as used on the early model 60 tractors. That part number is A4280R. Thanks, CLW but this is different from the number you gave. Which is correct?
CLW
06-20-2005 12:48:56
 Re: Conflicting Information in reply to Dave from Texas, 06-20-2005 10:51:28
Dave I just checked the A4280R and what that is, is the housing assembly ONLY. They are the same for the late A and the 60 up to 6054499. The number I gave you was for the entire pump. CLW
Glen in TX
06-20-2005 12:42:00
Dave, The A4280R is just the part number for the water pump housing and could also be AA6327R. AA5570R is the number for the complete water pump with pulley. AA5646R was the part # for the complete water pump plus the radiator bottom tank. The pump for A is the same for the earlier 60 but the later 60 pumps were different.
CLW
06-20-2005 12:38:13
Dave, I got the numbers from my DB1293 parts CD for the A starting with serial number 700200. I just checked and the 1998 Jul-Aug issue, page 6, said the A's before 700200 "could be retrofitted with the AA5646R Water Pump Assembly". To make matters harder for you it shows the 60 (6000001-6029999) used the AA5070R (sub. to AA6327R) Have you called your Deere dealer for a number? Where are you located? I am near McKinney.
CLW
Dave from Texas
06-22-2005 07:01:17
 Re: Conflicting Information in reply to CLW, 06-20-2005 12:38:13
Thanks for all the great information. I think I can now get the right parts.
I am in Richmond, which is outside of Houston.
