37A
LEO
02-25-2004 20:24:15
Guys, yesterday and today I put lots of your advice to good use.I opened the crank case cover and checked for sludge at the bottom , it had very little , I still cleaned it out . the screen around the pump was clean . I moved the flywheel and the oil pump shaft rotated so we are good there.
I changed the oil filter ( JD filter I took out looks much better made than the purolator I put in )
my three way valve is not holding very well and I broke the valve on the sediment bowl , so I drain the fuel after I run the tractor so fuel does not make its way into the cylinders.
Boys , what about the water temp gage ? can I replace it with any ol'auto parts gage ( that I asked before , sorry I did not save the answer )
I do keep an eye on the water , it does not boil but it sure looks mighty hot.
allright then guys , it is a little late over here , I will check back with you tomorrow.
leo
John T
02-26-2004 06:07:07
 Re: 37A in reply to LEO, 02-25-2004 20:24:15
Hi again Leo, glad to hear of your progress and thanks for keeping us posted. On that 3 way valve, you can buy a new outer seal, and clean polish n smooth n lap it into its bore, but I hate to even use them if I get one thats not leaking, but instead a sediment bowl shut off. On the sed bowl shut offs, removal of the outer nut, clean and polish the valve, and new seal/packing may cure it if it also leaks (or maybe just tighten the nut if all else is good).
YES, you can use most standard generic types of gauges but many of those have boo coo left over inches of cable which dont look that great all wadded up somewhere.
On the coolant, I would break down and give the entire system a good draining and flush and clean out, then replace with a pre mixed 50/50 water/anti freeze and maybre some additives mixture.
Good Luck n God Bless Ya
John T
Clooney
02-26-2004 03:11:13
Leo, you asked..."what about the water temp gage ? can I replace it with any ol'auto parts gage"...>>> Answ, sure you can use about any mechanical gauge that has a long enough cable on it to reach & has a fitting that will screw into the water pipe hole but most auto parts store gauges have way too long of a cable & look pretty bad all wrapped around.. That 37A gauge mounts off the back of the governor housing so uses a rather short gauge cable.. For not too much more money you can buy a gauge that says Deere on it & looks somewhat like the original. [white faced gauge]... Lots of places sell them from [K & K] to [Antique gauges]..
[email protected]
