1219 haybine adjustments
JDJACK
06-20-2005 09:57:49
I finally got my 1219 haybine going that I bought. Still need to replaced so old guards (make some knocking noise). Should there be wear plates on the first three guards by the sickle head and are those guards the same as the rest.
Also when I lower machine it sits low, I don't know if it's to low, adjusted shoes to lowest down position. And how much pressure should be on the shoes and how do I adjust ground pressure?
Any other advice on what to adjust and watch for would be great.
Tx Jim
06-21-2005 04:01:56
 Re: 1219 haybine adjustments in reply to JDJACK, 06-20-2005 09:57:49
JDJack,header float is adjusted at rear on large spring on each side.Tighten or loosen bolt to require 75/100#' of lifting on knockdown.Knocking noise can come from worn sickle head pin or loose sickle drive arm on wobble box.Tx Jim
