J D Model B Age
Harrison
06-20-2005 09:14:22
Can anyone tell me the age of my model B serial number 9828 and if it is worth salvaging it. Engine is froze and hood rusted out. Appreciate any info. Thanks Harrison
old
06-20-2005 10:05:47
 Re: J D Model B Age in reply to Harrison, 06-20-2005 09:14:22
As Rav siad sounds like a 1935 unstyled B Also known as a brass tag B. I'm sure its an 8 bolt because its a little later then the B I have which is #9405 and its also an 8 bolt. If you where close to where I'm at I'd give you a couple 100 for it. If it where my B I would fix it up, shot my B was stuck for more then 15 years before I got out and started working on it. I did keep the cylinders filled with tranny fluid till I got around to fixing it back up and last year my son drove it in the pardade of power at the local show, hes the 4th generation to drive that tractor, was my grandfathers before he died.
Ravgardner
06-20-2005 09:33:50
The serial number of 9828 would indictate that was made in 1935, the first year of production for the Model B. If I owned it, I would salvage it. Go to the front and count the number of bots used to hold the steering pedestal to the frame. Does it have 4 or 8. A 4 bolt B is worth a bit more than an 8 bolt.
