Broken bolt removal
Greg A
06-20-2005 05:26:08
My 630 has 2 broken bolts around the pto shaft, the bolts are broken off about a 1/4" into the cast housing. Someone has attempted to drill 1 bolt but got off center and into the casting, I attempted to drill into the other bolt to try an easy out but the bolt is so hard I can't even scratch it (I have fairly good drill bits). Does anyone have any suggestions how I mite remove these broken bolts.
Van in AR
06-20-2005 11:12:20
 Re: Broken bolt removal in reply to Greg A, 06-20-2005 05:26:08
If you heat the bolt red hot and let it cool it will soften it so you can drill it easier.
Van
Dave from Texas
06-20-2005 07:29:57
If it is broken down in the hole about the only way is to blow it out with a torch and then retap it to clean the threads. I have welded studs or nuts to the remaining bolt if it is flush or a little above the hole. I have filled the hole with weld metal a couple of times. This only worked about half the time. I used these methods this past week on all the bolts on an A's radiator. Every bolt broke!
Greg A
06-20-2005 12:11:06
 Re: Broken bolt removal in reply to Dave from Texas, 06-20-2005 07:29:57
how do you blow out the bolt with a torch and not damage the casting, what precautions do you need to take to avoid really messing things up.
jacksun
06-20-2005 18:39:12
 Re: Broken bolt removal in reply to Greg A, 06-20-2005 12:11:06
i have used a torch to remove broken studs in castings to and have had better results than drilling you start cold and try to heat up the stud or bolt if you have a little hole in center works better when red hot and centered on bolt blast it with oxy and it will blow it out. it wont cut the threads usually because of the rust.
