720d wiring
Don Dittmar
06-20-2005 04:44:40
Hello all.
I have a 1957 720D with pony start and I was wondering if anybody could get me a wiring diagram for this tractor. The current wiring is in bad shape and has been "repaired" with evrything under the sun, so I would like to completley rewire the tractor. I am keeping it 6 volt with the original 6v generator and all the original switches. thanks in advance for all the help
Don Dittmar
06-21-2005 04:10:48
 Re: 720d wiring in reply to Don Dittmar, 06-20-2005 04:44:40
I will take a look at my parts book and see if I can make heads or tails from it, if not I will get a new harness, sounds like the easiest way to go
Spoker
06-20-2005 18:58:35
Like 720Deere said. Order a new harnes from Agri-Service and you will not regret it. The wires come numbered and a list will tell you where to place the wires on which terminal. I did and had good luck on replacing the harnes by Jim"s instruction. The Harnes looks original from Deere.
720Deere
06-20-2005 14:40:23
The parts catalog does a fairly good job of describing where all the wire connect. You would be much better off to purchase a complete harness from Jim Guarino @ Agri-Services. I have installed his product and it is top notch. Don't quote me, but for just the engine harness your looking at about $75. The lights and such aren't so hard to wire yourself, but his harness will make a neat job.
Kevin L.
06-20-2005 10:14:38
you might search for other post on wiring harness or in the green magazine to purchase the whole wiring harness. if you are not pickie about the colors the JD SM & IT SM have a not so good diagram and will be glad to share them. If I find much more wrong on mine, I'll be purchasing the harness too.
