4430 slow lift
charlesmm
06-19-2005 23:56:30
On first starting up the rockshaft seems to take forever to lift ,then for the rest of the day it lifts very slowly,I have had this implement on the back , a mower and not heavy for ages without problems before.I have changed the main filter,checked the pickup filter ,the filter relief valve is not sticking ,the oil does not get hot after 2 hours of work in a heatwave in England this weekend , and the implement does not settle after switching off the engine. It's a late model with O ring valves which are not supposed to stick.I don't have any pressure testing gauges . the book says also mentions pressure valve and return valves sticking, are they easy to access ? I can live with this problem,will it suddenly give up completely in my field furthest from the farm?is it damaging anything ,any ideas from experienced people on what is wrong?
many thanks in advance.
msb
06-20-2005 19:44:12
 Re: 4430 slow lift in reply to charlesmm, 06-19-2005 23:56:30
Pick up filter? You mean the suction screen in the bottom of the transmission case?If not, that is the place to start. Brakes work o.k.? Noisy? Your main hydraulic pump may need to be overhauled.Does it need a spot o tea/ Joking!
charlesmm
06-20-2005 00:43:24
forgot to say that at first there was no steering either ,which I knew was the stroke control valve ,but after 5 mins the steering recovered but nothing from the lift then after another 5 mins the slow lift which I have had now for 5 hours or so of work. Just some more clues for detective/mechanics
T I A
