430 Hood fastener pin installation ?
Dave - Ia
06-19-2005 19:36:26
What kind of tool is used the install the pins in the studs that hold the hoods on a 430? I have tried a notched pair of channel lock pliers without success. I can get them started, but not pushed through far enough. Any help would be greatly appreciated.
Henry J
06-20-2005 05:20:43
 Re: 430 Hood fastener pin installation ? in reply to Dave - Ia, 06-19-2005 19:36:26
Dave
I can tell you how i got them out, and I plan on putting them back in the same way.
i used a curved jaw vice grip for the driver. I did not have a chunk of scrap iron around thick enough to let the pin pass through without hitting the jaw of the vice grip so I used a nut. I drilled a hole in the nut opposite the direction that it was threaded (crossways). the hole has to be big enough to allow the cross pin to enter without bottoming out as it is driven in or out. so I put the hole in the nut over the pin and took the jaws of the vice grip with one jaw on the nut over the pin or hole and the other jaw pushing on the exposed pin end. These studs were ancient so i heated them once with a portable torch, put some kryoil on and they came out with a bang.
I plan on reinstalling new ones in the same/opposite manner since they have a groved portion in the center. They should start enough by hand and then take your other "three" hands for getting the nut over the hole, setting up the vice grip and adjusting it down as you push the pin in.
Let us know if that don't work. Personally, I am not near strong enough in the grip to match the pressure of a vice grip with a channel lock and the vice grip gives good steady controlled pressure.
I have heard of drilling a hole in one jaw of the vice grip for the pin to pass when pressing, but i found that to be kind of a challenge and the jaw was harder than the bits i keep in the barn.
ChuckW
06-20-2005 04:37:20
drill the hole slightly larger but enough to allow pin expansion to hold...this was a factory setup and you'll need to improvise a little.
ChuckW
06-19-2005 19:41:55
I used vise grips with the curved jaws and they seem to work good...you're working a little off set unless you want to trash a pair and cut a center grove..
Dave - Ia
06-19-2005 20:08:00
 Re: 430 Hood fastener pin installation ? in reply to ChuckW, 06-19-2005 19:41:55
How hard do they push? I notched a pair of 12"pliers and can not get the groved part of the pin to push through. I would think that I have about the same leverage with these pliers as vice grips.
