Difference in 2020 and 2030
Greg Lawson
02-25-2004 18:44:27
Can anyone tell me the major differences in a 2020 diesel and a 2030 diesel? I know the 2020 is 54HP and the 2030 is 60HP but what about the weight and structure of the two? Tire sizes the same? Same loader for either?
David
02-26-2004 05:23:23
 Re: Difference in 2020 and 2030 in reply to Greg Lawson, 02-25-2004 18:44:27
The American old style Dubuque model 2020 and 2030 are like Mike said, identical tractors with different engines. There was also a new style Mannheim model 2030 made from 1975 to 1980 which is very different from the Dubuque version. If you have a preference, be sure to verify the model. David
MIKE HANLEY
02-25-2004 19:35:02
Per the salers lit Loaders recomeded for eather tractor 37, 47, 48, 143, 145, and the 146 loader.
specs on 2020;
4 cyl gas (53 HP) or diesel (54 HP) The 2020 came in a regular utility, and had 28" tires, a low utility and had 24" tires and a high utility that had 38" tires. closed center hyds. with 13 gal per min pump. Basic equipment was; 8 speed transmission Constant mesh. 3PT CAT II with solid lift links. all the gages. The RU and the LU had 8 position adjustable steel wheels. The HU had 8 position cast wheels.
Fenders with lights. Power steering. (Optional on 1020 and 1520) Continuous 540 PTO. SOME OPTIONS; 3PT with telescoping lift links. HU specs 61" to top of hood 87" top of muffler 69 1/2" wide 129" long Shipping wt GAS 5,500# Diesel 5,580# Differant lock. Independent 540/1000 PTO. Deluxe seat. Heavy cast wheels Rack and pinion rear wheels. Sweptback front axel. Side frames Roll guard with seat belt. Hi-LO transmission Direction reverser
2030 Also came in a low, regular, or high utility with thew same tires siges options as the 2020. Reading the rest of the regluar and optional equipment, It's pretty much the same straight across the board. Every thing except the engine which was 60 HP in the 2030.
