Buckeye Al -- Thanks for your very well written explanation. I spent about an hour at the hydraulics shop today and your idea is one they didn't come up with... Let me see if I understand them (and you) correctly... I broke into the pressure (and return) lines using tee fittings. They are compression fittings designed for 3000psi. They weren't cheap. As a result I have two "open" center valves (actually three - since the loader has two spools). As a result of having the multiple open center valves I can't run the loader without first pushing the powertrol lever forward (which in effect makes it a closed valve. And I can't run the rockshaft because the loader spool has two open valves... The hydraulics shop recommends a high pressure "T" ball valve - requiring I throw the lever to either the powertrol or the spool. I understand exactly what you are telling me to do, and I like your idea better. With your plan of attack would I have to engage the powertrol lever to make the spool run? I'm thinking not... I'm still trying to understand the power beyond port... unless I install a second reservior and totally isolate it from the Powertrol I don't think it will work right. AL -- I'm going to try to find a fitting that will work as you recommended. I appreciate everyone's advice and recommendations. I really enjoy this forum. I will repost once I have the problem solved. Tom in Montoursville, PA
