Head gasket for '44 model A
Don E. Foster
06-19-2005 13:29:35
I have a '44 Model A, SN 533145, and need a head gasket. The implement people say gasket # R520678 is the right one, BUT IT SURE AIN'T!!!! Any ideas?
Also, what is the plug on the upper left on the valve cover that opens into a channel that runs across the inside of the cover?
Thanks.
Mike M
06-19-2005 17:30:44
 Re: Head gasket for '44 model A in reply to Don E. Foster, 06-19-2005 13:29:35
That plug and channel you describe sounds like the rocker arm oil trough in the valve cover.The unstyleds had these and the early styled but I didn't think that they went up that far to 1944 ???? Double check in a parts book all your casting numbers of your head and block someone may of put on some earlier parts ???
Island A
06-19-2005 17:50:17
 Re: Head gasket for '44 model A in reply to Mike M, 06-19-2005 17:30:44
The Late Styled starts 1947. The 1944 year is early styled and should have the early valve cover.
Dave
Mike M
06-20-2005 03:48:46
 Re: Head gasket for '44 model A in reply to Island A, 06-19-2005 17:50:17
I gotta get my parts books moved over to home.
44' maybe ? but by 45' and for sure 46' that valve train gets oiled up through a passage in the block. Like I say I gotta go check but I'd say the cut off was between 41' and 42' when they went from 4 speeds to 6 speed trans.
Island A
06-20-2005 07:14:26
 Re: Head gasket for '44 model A in reply to Mike M, 06-20-2005 03:48:46
Okay. I thought the change was with the late styled. Hold on... parts book says...
A68R to sn 487999
A2347R to sn 583999
AA4016R sn 584000 and up.
So the above tractor should have the A2347R which I believe gets oiled through a passage in the block like Mike M said.
Dave
Drew
06-19-2005 15:18:20
Get a Fel-Pro, pn# 7744-sbx from your local auto parts store. Its a better gasket than the Deere, and half the price.
Island A
06-19-2005 13:46:29
Parts book says A2329R
indeed it does translate into new Deere part #R520678
Dave
