36 JD B piston
charles
02-25-2004 18:30:54
What are the wrist pin piston bore for 36 B with a 4 1/4 piston? Where can new wrist pins and bushings be brought for this piston or maybe a std rebore kit?
Mike M
02-26-2004 12:06:43
 Re: 36 JD B piston in reply to charles, 02-25-2004 18:30:54
I was able to have an engine machine shop order
some piston pins that ended up being just right to oversize in the pistons and rods they were just a little long but trimmed up easy with a carbide bit in a lathe. Not all of them have catalogs that list piston pins but there are companies makeing them..
John - just a thought
02-26-2004 06:34:17
Just a thought but depending on how bad the cylinders are and wheather or not you can find a set but the early styled pistons 4.5" have the same pin diameter and same pin location. Plenty of meet in the block to bore it .250". If it doesnt clean up after that .....>>!!!!
Duane Larson
02-25-2004 20:21:06
Charles,
The piston pin hole id in the piston is 1.231 - 0.001, the piston pin od is 1.230 - 0.001, and the bushing id is 1.232 - 0.001. The 0.001 numbers are the tolerances on each number, ie, the holes may be larger by 0.001" and the pin may be smaller by that amount.
Earl S.
02-25-2004 18:38:51
Try 815-778-1900 Jerry Hinrichs has rebore kits.
