4020 is all it is cracked up to be
Toby
06-18-2005 17:11:36
I have several tractors but my latest buy 20 years older than my oldest is a 4020. There is no doubt that it is the best driving tractor I have every been on. Cutting hay is now fun because it is the perfect size and drives like a Lexus. I now see the magic of a 4020 wished I had seen it 35 years ago. My next goal is to find a late model low houred one to replace a ts100. Wished mother deere would make a few more.
Toby
James2
06-19-2005 10:55:10
 Re: 4020 is all it is cracked up to be in reply to Toby, 06-18-2005 17:11:36
From what I have seen a low houred 4020 will bring $20K+. A friend sold a high hour, power shift, side console for a little over $20K. The 4020 was/is a great tractor, but a lot of tractors can be bought cheaper and also do an outstanding job. If it needs to be a JD, a 4320 comes to mind. It's basically a turbocharged 4020 and from what I have seen brings $5K less. I have a 1971 low hour MMG950 bored to a 1050 giving 120 dynoed pto hp. It's a excellant running tractor for $6500 but I admit it isn't nearly as nimble as a 4020. I was reminded of this when I was looking at/operating a 4320. I can see why MM died, no way anyone would consider a G950/G1050 at any reasonable discount. But, how about a low houred G950 vs a high hour 4020 for $14K less?
buickanddeere
06-18-2005 19:23:51
Nostalgia is part of the 4020's perceived value. It's the same way old timers reminisced about the two cylinders 20,30 & 40 years ago. Mother Deere still makes a 4020 but it's improved. It's called the 6603 and can be had with M4WD. Optional Sound Guard Body, it's cheap to purchase and the fuel & parts savings will pay for it's self vs. an antique 4020.
Doug in IL
06-21-2005 07:28:04
 Re: 4020 is all it is cracked up to be in reply to buickanddeere, 06-18-2005 19:23:51
Nostalgia may be a part of it now, but the 4020 was always a premium priced tractor on the used market. They are rock solid tractors and don't have plastic parts. You could buy a 6603 today along with a good 4020 and 5 years down the road the 4020 will probably sell for more than the 6603.
buickanddeere
06-21-2005 23:23:22
 Re: 4020 is all it is cracked up to be in reply to Doug in IL, 06-21-2005 07:28:04
The 6603 will burn less fuel to do the same work and make up the difference even if resale price dropped. Odds are the resale price of the 6603 would not drop as long as it wasn't bashed up. That M4WD and almost a Sound Guard Body beats any 4020 too. A full factory warrenty sounds good as well. At least plastic doesn't rust and todays plastics are better tha the stuff 30 years ago.
msb
06-18-2005 18:56:30
Now you know why some people say the 4020 was a classic in every sense of the word.
mike brown
06-18-2005 17:21:30
The very attributes you described is why your going to have a hard time finding one with low hours. If you do it will cost you plenty. I tried to find that same tractor a few years ago but bought a 4230 (no cab) with fewer hours for less money.
