Depressed -- need help with L
Chuck in MI
06-18-2005 05:50:09
I'm working on a late model styled L with the JD engine. I will start by saying I had this tractor running about a year ago when I decided to pull it apart and paint it. Life got in the way and it took alot longer to get it done than expected but now she's pretty as a picture, only one problem, now it won't run! It will hit once or twice but never get over the hump and take off. Also fires back through the carb frequently when cranking (hand crank, no electric start on this one).
I have checked the following:
Timing is right on. I checked it even though I never touched the mag, since it was running, only masked it off for paint. I have acceptable spark and the points (.015) and plugs (.025) are clean and adjusted to the specs on this site.
Seems to have plenty of compression (my arms feel like they are going to fall off soon!) and I have checked for stuck or non-seating valves by using an adapter in the spark plug holes and charging the cylinders with compressed air.
Sealed the intake and carb gaskets to eliminate the possibility of vaccuum leaks at those areas.
I have checked to make sure all the carb passages are clean but now have the carb off again to check it once more and check the float level as it seems to flood (gas running out of carb, but not wet plugs) easily.
Question #1: What should the initial main and idle needle settings be to start with?
Queation #2: What else should I be looking for or what am I missing?
This was going to be a simple repaint and has turned into a big pain, in my right arm especially!
Sorry for the long post, hope one of you all can help.
Chuck in MI
06-19-2005 07:55:11
 Re: Depressed -- need help with L in reply to Chuck in MI, 06-18-2005 05:50:09
Guess I'll try to pull her and see what happens. I did put new plugs in before I started to get her up and running again. Acts the same with the old and new. Mike, my carb does have an adjustment needle in the main jet but I don't know how many hands have been on this tractor before mine. I guess I'll try the 1 1/2 turns on both and see if she'll go. Also a buddy of mine gave me another mag off an LUC to try but I think I'll leave mine on and pull it to see what happens first.
Thanks for all your replies. I just hope this thing doesn't turn into a real pretty (and expensive) lawn ornament!
Carl NY
06-18-2005 13:07:54
I had a 39 L that would act the same way after setting for a long period of time. I believe the compression may be low and you are not spinning it over fast enough. I always had to tow mine. After it ran for a while it was good to go. Once it started it would fire up every day.
Mike M
06-18-2005 07:08:42
There is no main adjustment as those have a fixed jet,idle screw I'd guess 1 to 1 1/2 turns out ? Those models will flood gas out the carb. but it is not getting up to the engine. I have had this trouble when they sit for a long time. I'd put in some new plugs and try pull starting it in high gear or coast it down a hill once you get it running and everything loosened up and lubed up it should start by hand better. Try hand starting it like the book says I have had much better luck this way. Open the throttle wide open (fast idle) then choke full on and keep it on no matter how much gas runs out the bottom as it needs to get up to the plugs,if it pops this way it should catch and keep running enough so you can open up the choke.
Maark
06-18-2005 06:58:56
put some new plugs in it.
Hoosier JD
06-18-2005 09:44:11
 Re: Depressed -- need help with L in reply to Maark, 06-18-2005 06:58:56
This may seem silly....but has happened before. Are the plug wires in the correct position? Just a thought. Good luck. Mike
