2520 3-point shaking (w/load sensing)
krosckes
06-17-2005 13:36:51
Once a year, I use my 2520 for plowing with a 3 bottom semi-mount plow. If the draft sensing lever is in the "L" or "LD" positions, the 3 point arms chatter (rattle & shake vigorously) when the linkage senses that more traction is needed. The shaking does not occur when the draft lever is in the "D" position. The trans dispstick shows full, and the main (front) pump was rebuilt about 100 hours ago. All other hyd functions work fine. I don't use the draft very often so I have not been aggressive about fixing it. If anyone knows what is causing this, please share. Thank you.
msb
06-17-2005 20:37:22
 Re: 2520 3-point shaking (w/load sensing) in reply to krosckes, 06-17-2005 13:36:51
Sounds like the adjustment procedure need gone through on your tractor.
