7800 PTO will not stay engaged
JD ROAR
06-16-2005 22:33:27
The JD 7800 I have will not turn the PTO for more than a few seconds before the panel PTO annunciator starts flashing and it shuts off.
I selected the PTO rpm on the display and it never shows any (even when it briefly starts).
Could there be a rotation sensor problem or is it something deeper?
G/MAN
06-18-2005 13:35:19
 Re: 7800 PTO will not stay engaged in reply to JD ROAR, 06-16-2005 22:33:27
I agree with Gord. Probably something in the speed sensor circuit. If the tractor electronics "see" that the PTO was turned on by getting the signal from the switch circuit itself, but don't "see" the shaft turning because of a fault in the sensor circuit, it will shut the PTO off because it thinks that the PTO clutch is slipping, or that there is some other problem that could lead to damage. More than likely a failed sensor or bad connection at the sensor, but a bad wire somewhere is also possible.
Gord
06-17-2005 17:10:24
The PTO speed sensor has to show pto speed within a few seconds. If it doesn't send a speed reading to the CCU then the PTO shuts off. Check the wiring to the speed sensor just above the PTO shaft to see if it's unplugged, wires broken, or it may be a bad sensor.
