Others on here probably have more experience but the first thing I would suspect is the differential. The problem has to be at the differential or back. If it was a broken tooth you would probably hear it. I would check the differential bearings and the bevel/spur pinion for the right wheel. Pull the transmission top cover and you should be able to reach in with a bar. See if you have excessive play in the bearings and gears. It would also be easy to pull the right brake to inspect those gears and the bull gear. And other thought, the rear axle bearings could be worn causing it to bind. Jack the right side up by the housing and with a long bar and block see if you can get any up and down movement in the axle. Be careful, if it is binding that hard it could end up breaking some teeth. The first thing I thought of was a tooth was broken off and the piece was getting picked up by the bull gear. But that wouldn"t be isolated to the right side. Something to think about until someone with more experience provides some input.
