3020 GAS
Playfarmer
06-16-2005 19:15:43
I think I just found why nobody likes John Deere gas tractors. Tonight I was disking with my recently purchased 3020 gas, it has been a little hard to start so I had replaced the plugs,points,rotor,condenser and plug wires. that did help but when I shut it off tonight I tried to start it right back up and could not get it started so in the process I managed to flood it. Took the hose off to the carb and gas ran out!!!!! Guess I choked a little to much. My question is would eltronic igition help along with the hotter coil also? It does have the aluminum carb that I see on this forum is classified as junk. Any advice would be appreciated. Thanks
SMA in NE
06-18-2005 07:30:16
 Re: 3020 GAS in reply to Playfarmer, 06-16-2005 19:15:43
I have a 4020 gas burner that I purchased over the winter. It has a MS carb that I overhauled, you should replace the "accelerator pump/diaphragm". If it has a small hole in it the tractor will run rich. Mine runs well now with the MS carb. I use it to put up 150 acres of alfalfa. It pulls a 16" windrower, 12 wheel V rake, and a JD 535 baler. It is using about 5 to 5 1/2 gallons of gas per hour. The 4020"s came with a 6 volt coil. The pertronix ignition uses 12 volts. I had a pertronix on mine and it would not run right until I put the points back in. There is a resistor on the key switch that only allows about 8 or 9 volts through to the coil. I believe if you are going to put electronic ignition on this tractor you need a 12 volt coil and will also need to bypass the resistor to get it to work properly. My 4020 also starts hard when warm (hydraulic pressure built up). I am considering getting the pump kit to relieve hydraulic pressure when starting. Supposedly is about $300 from John Deere.
Playfarmer
06-17-2005 14:15:37
I am going to get eltronic ignition and the hotter coil tomorrow also the guy I talked to (old john deere mechanic) said try A/C C-87 spark plugs along with when you try to start it turn the steering wheel as this release some of the pressure on the hydraulics (????) Don't know but will try it. He also said that a starter for a propane tractor works better as it is more heavy duty and will spin the motor faster. One more idea he gave me was to install two batteries like the diesel has. Haven't tried any of this yet but will post back on my results.
krosckes
06-17-2005 13:57:05
I have experienced similar behavior with my 2520 gas (although not the same engine as the 3020). It also has a Marvel carb. I upgraded to electronic ignition and installed a hotter coil for around $120. This improved cold starting but not warm starting.
I once read an article in "Green Magazine" about problems with New Gen gas engines. I don"t know when the article was published, but it mentioned two solutions: 1) JD used weak starters on gas engines, so find a bigger starter (may have to go aftermarket). 2) when the tractor is cold, the main hyd pump has no back-pressure. When the tractor is warm, there is residual pressure in the pump making it harder to start. JD offered a "relief kit" to help release pressure off the pump when starting, but I don"t know if such a kit is still available.
Thanks to all of you for recommending the Zenith carb. I am going to investigate if I can get one for my 2520.
Mike M
06-17-2005 16:45:51
 Re: 3020 GAS in reply to krosckes, 06-17-2005 13:57:05
I don't think that the 2520 had the same kind of a Marvel Schebler carb. as the 3020 4020 yours should be cast iron and should work fine if rebuilt properly. The others are a square aluminum box looking thing the has a cover below the fuel level that is prone to leak and it also contains a diaphram type accelerator pump that doesn't hold up or work well.
mgb
06-17-2005 06:32:03
 Re: 3020 GAS problems also!!! Help!!! in reply to Playfarmer, 06-16-2005 19:15:43
I'm glad you posted this. I have a 3020 gas that I recently bought. I think people on this forum are tired of my questions. The former owner told me when I bought it that the first thing I should do is buy a Zenith carb and chunk the junk Marvel that's on it. To make a long story short I have so far tried the following: Overhauled completely the M/S carb once. Took it apart and cleaned it three times. Changed the points-plugs(2 times)-condensor-coil-rotor. And guess what? It still pops and sputters and misses like it had a half tank of water mixed with the gas and blows a column of black smoke whether at a dead idle or wide open. Hope you get yours fixed. Let me know (please!) what you do to fix it. I guess I will break down and buy the Zenith carb for mine. But I hate to spend the $$$$ and that not be the problem.
I'm starting to wonder about the valves or maybe piston rings or something. There has to be a reason for this.
Mike M
06-17-2005 08:19:48
 Re: 3020 GAS problems also!!! Help!!! in reply to mgb, 06-17-2005 06:32:03
If you wonder about valves and such do a compression test and also adjust the valves. I include these steps as part of a tune up. Do yourself a BIG favor and get ahold of a Zenith Carb. I have even worked for a carb. rebuild shop and have worked on several carbs. and that Aluminum MS is the only one that I couldn't get to suit me. I finally gave in and tried a Zenith. I got a super good deal on one from a 3010 or 3020 or something and put it on my 4020 and it was the single biggest improvement I made. Mine had an adjustable load needle and I figured that they all use the same bore and stroke just 2 more cyl's to feed I couldn't figure out why 3020 and 4020 called for different carb. numbers. Ebay has them and the aftermarket was even reproducing them. Get a Zenith on there.
Mike M
06-17-2005 05:30:58
I am one person that really likes our 4020 gas.The only time I don't is when I work it hard and have to refuel it ! LOL You can sure run alot of gas through one. I will tell you that the single best thing I ever did was to get rid of that Marvel Schebler carb. and get a Zenith. I am still running points and condenser and never had a problem with them in at least 10 years so far since I got it and did a complete tune up.I specificly wanted a gas one for our loader tractor because it does alot of starting and stopping and short little jobs and needs to start when cold to blade the snow.The colder it gets the better it starts,you do need to swith the manifold to hot so it warms up.
Deere Farmall
06-17-2005 03:54:34
My John Deere 3020 Gas was hard to start, and ran terriable for about 1/2 hour until it got warmed up. Installed electronic ignition and opened the spark plug gap to 35 thousands and now it starts easier & only takes a 5 minute warmup after starting to run good and runs much better. You might check the coil. The power to the coil runs thru a resister (either wire or ballast resister) to lower the voltage to 6 volts, then a 6 volt coil is used. There is also should be a wire leading from the solonoid to the coil to provide 12 volts to the coil for easier starting.
