6 volt positive ground switch to 12 volt 1 wire al
Walt in Jaxn Tn
06-16-2005 16:11:32
Friend of mine wants to switch to 1 wire alternator, he has a DR distributor and a 6 volt coil. Question is does he replace the coil with a 12 volt and replace the light bulbs or, use a resistor? --Walt--
Jake
06-16-2005 20:34:23
 Re: 6 volt positive ground switch to 12 volt 1 wir in reply to Walt in Jaxn Tn., 06-16-2005 16:11:32
If the 6 volt system works then I'd just leave it along. I have a 1950 B that is used infrequently. I put an alternator on it because it charged and regulated better for my short use. I used a 6 VOLT regulator in the alternator. You can get a 6v or 12v 1-wire regulator for those Delco Remy alternators. This way you can leave everything in the electrical system the way it is. The only thing you might want to change is to swap the wires on the amp gauge so the needle points the right direction.
John T
06-16-2005 18:34:36
A Ballast Resistor is probably cheaper than buying a new full 12 volt rated coil if that matters, but either method will work fine. Tractor Supply Houses like Rural King or Central Tractor or Tractor Supply or even auto stores like NAPA have them. They are typically 1.5 to 1.85 ohms at around 25 or so watts.
Like you noted, he will need 12 volt bulbs (or use two sixes in series) and my guess is his new alternator will be Negative Ground??? If so, the ammeter leads would need to be reversed.
Post back any questions
John T
buickanddeere
06-16-2005 17:49:01
What is wrong with the 6V system?
Walt in Jaxn Tn.
06-16-2005 17:59:37
 Re: 6 volt positive ground switch to 12 volt 1 wir in reply to buickanddeere, 06-16-2005 17:49:01
Not sure, he just wants to change over.
