1020 maunual steering
T.A. Long
06-16-2005 14:50:51
I recently lost steering on my 1020 (maunual), happened during during a sharp turn, felt like a key or pin shear; before I do a complete steering overhaul (per shop manual), can anyone offer any suggestions? Any help would be appreciated. Thanks.
T.A. Long
T.A. Long
06-20-2005 07:55:13
 Re: 1020 maunual steering in reply to T.A. Long, 06-16-2005 14:50:51
According to the parts breakdown, it doesn't look too complicated. Thanks.
ck92
06-20-2005 07:34:13
I have a 1020 with manual steering and this happened to me a few years ago. Inside the steering column is a worm geared shaft connected to a yoke with ball bearings in it. You probably broke the retainer that holds the bearings in the yoke and they fell out. You will have to drain the column and remove it from the tractor. But check the manual I believe there is an inspection hole on the right side where the yoke connects to the steering arm, could be broke there.
T.A. Long
06-20-2005 08:04:26
 Re: 1020 maunual steering in reply to ck92, 06-20-2005 07:34:13
Thanks for your help.
