2640 power steering console extremely hot
Cory
06-16-2005 05:15:38
third party image
Our 2640 has been having some hydraulic problems lately. After working with it a while (hour or two) the hydraulic fluid becomes very hot. The power steering console gets too hot to touch, the loader doesn"t want to work to well, as in sluggish. Also, the 3 point lift won"t lift unless you use the loader joystick. Any suggestions before we take it to our local John Deere stealership to get worked on?
Thanks Cory
pduck
06-19-2005 08:00:56
 Re: 2640 power steering console extremely hot in reply to Cory, 06-16-2005 05:15:38
Please let me know what you find out, I have a 2630 2ith the same problem, no loader but the lift responds slow, very slow when it's hot.
And what is an "internal leak"?
Thank you,
Duck
txgrn
06-17-2005 03:53:45
I agree with Jake. The Deere uses a closed hydraulic system and supplies fluid ONLY on demand. A leak would keep a steady requirement on the system for fluid which would eventually cause pump/fluid overheating.
Mark
Jake
06-16-2005 20:38:41
You most likely have an internal hydraulic leak somewhere. The leak is usually near the hottest spot. Feel the steering vale, transmission case, rockshaft housing, etc. Feel all over everywhere for hot spots.
