2010 Crawler Final Drive RR
jan nelson
06-15-2005 21:59:02
When pulling out steering clutches, I discovered that the left final drive shaft axle bearing is toast. When following the book to remove the final drive, I get to the point where it is loose, but two studs keep it from coming all the way free. It appears as if a track tensioning spring housing that attaches to the rear support cross member needs to be removed, but there is no mention of that in the manual.
Anyone have experience here?
Thanks,
Jan
