First to all who have chimed in on these threads to help me I give you my sincere thanks. If not for you guys I would have given up, and it wasn't even that big of a problem.I'll be darned if I go back to Burrey carb for work in the future though. Here is what happened. Frustrated and angry today I went out to work on the A. I removed the carb drain cock and placed a nipple with a clear 3/8 tubing on there, routing it up over the carb. Turning on the fuel yeilded a fuel level in the bowl well below spec. I'd say about 1 3/4 inch below the gasket. I didn't want to go into that carb, thinking I would mess it up, but it was the last thing I hadn't checked so off the bowl came. The bowl was full of crud! It looked like paint, after you spray it with oven cleaner! Big peels, all in the bottom of the bowl! So I cleaned the bowl and bent the float lever to yeild a better setting and reinstalled the bowl. Turned on the fuel and the level came up to around 3/8 to 1/2 inch below the seal. Now we're talking. Hit the starter with about 1/2 choke and 1/4 throttle and she fired up and idled slow and ran fine the rest of the day. I still need to adjust the settings on the carb to get a smoother idle, but as of yet I haven't been able to smooth her out. BUT SHE RUNS! Under load she runs REAALLLLY smooth, but idles quite rough. Thus ends the frustration, and it looks like I will make the tractor show/pull after all. THANKS AGAIN YOU GUYS!!! Dave P.S. I think I am going to change my name to Island A, tractordave sounds dumb and was all I could think of at the time. Dave
